BMW CIC PATCHER v2
BMW CIC PATCHER v2
BMW CIC PATCHER v2
BMW CIC PATCHER v2
GENERATE YOUR RETROFIT FSC CERTIFICATES
Far easier than emulators, script activations, hard map updates...
** NO BOOTLOADER MODE **
** DONE IN 10 SECONDS! **
** NO BRICKING **
Note : SUPPORTS ONLY US AND ECE LATEST VERSIONS OF SOFTWARE, SO IF YOU HAVE US or ECE CAR, UPDATE YOUR CIC SOFTWARE AND ENJOY THE PATCH!
BMW CIC CRACK V2
This is patcher for BMW CIC Professional Navigation, it patches binary file
and replaces root certificate what enables you to sign your own FSC certificates
from within FSTOOL or E-SYS like OEM. After patching, Self-generated certificates
will be accepted as OEM ones.
Pre request
1) This is ONLY for US (United States) and ECE (Central Europe) software versions!
2) You should update your CIC software to the latest before applying the patch!
Unlike other patches floating around, this one is done in 10 seconds or less. There are no need
for multiple reboot, or hang in Bootloader mode which exposes the system to bricking or failure.
HOW TO USE IT
1) Format USB drive with fat32 filesystem
2) copy file 01_PATCHER\USB_AUTORUN\copie_scr.sh to empty USB drive
3) Insert USB drive into CIC, wait until reboot and you're done!
(if CIC will not reboot in 20 seconds, it means that there is software incompatibility or already patched, read pre requests)
After cic has been patched and it restarted you can fire-up E-SYS or FSTOOL. If you go ahead and check status of FSC you will see that
CIC has been virginized and only root certificate is accepted. Key you should use for signing FSC certificates is 00_PRIVATEKEYS\fscs.der
other two private keys (root.der and sigs.der) you will have no use for, they are included just so the cert chain is complete.
To make certificates for your VIN you can use files in folder 03_FSC_TEMPLATES from archive,
load them in E-SYS (FSC Editor) or FSTOOL, change ONLY VIN, sign them and save as.
** VERY IMPORTANT: If you do not know what you are doing, when modifying template certificates, change only VIN to match yours,
do not edit other fields including date of issue.
After making all certificates you will need for your retrofit you can install them normally via FSTOOL or ESYS, other needed certificates
as SIGs and FSCs cert you can find in folder 02_CERTS from this archive.
Source code of the crack/patch and all relevant data will be published on CarTechnology.co.uk forum
BMW CIC PATCHER v2
BMW CIC PATCHER v2
** NO BRICKING **
BMW CIC CRACK V2
Pre request
HOW TO USE IT
- BMW WDS v15 and MINI WDS v7 Wiring Diagram System
- BMW WDS V12.0 Wiring Diagram System for BMW vehicles
- BMW Motorrad (RSD) Repair and Service Data [09.2017]
- BMW TIS VMWARE WorkShop & Repair Manuals 08.2017
- BMW ETK Spare Parts Catalog 01.2019
- BMW MOTORRAD (RSD) REPAIR AND SERVICE DATA [09.2016]
- BMW KSD2 [05.2016] Service Information
- BMW,MINI,ROLLS-ROYCE ETK [04.2016] Spare Parts Catalog Full Instruction
- BMW & MINI SP-Daten v65.0 FULL Pack [06.2018]
- BMW Carsoft 6.5 SP1 + Cracks
- BMW ETK Spare Parts Catalog + Prices Euros [05.2016]
- BMW TIS WorkShop & Repair Manuals [12.2007]
- BMW KSD2 Service Information [12.2015]
- BMW KSD2 Service Information [02.2016]
- BMW Education Info PDF Manuals
