Base Firmware Genset Incal 06.2016
WebIncal(PGA) Release :v15.12
Release Date : April 26, 2016
Summary :
Cummins Power Generation has released the following new calibrations and feature Files for April 26, 2016
New Calibrations
3 - Genset
4 - Operator Panel
61-PCC3300
82-HMI320
98-PCC2300V2
103-HMI321
110- Universal Simulator
New Features
61-PCC3300
71-PCC1302
94 -PS 0500
98-PCC2300V2
Detailed Description:
Cummins Power Generation has released the following new calibrations for the April 26, 2016
New Calibrations for 3 - Genset
PART#,REVDATE,DESCRIPTION
A031A351,7/1/2014 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLD,2750KW,60HZ)
A051W239,6/11/2015 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC 1650KW 50HZ 168 T PAR)
0326-5997,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLA,2700KW,60HZ,PAR)
0326-5993,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH,2250KW,60HZ,PAR)
0326-5989,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH,2000KW,50HZ,PAR)
0326-5985,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,2000KW,50Hz/60Hz,PAR)
0326-5941,3/12/2013 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKD,1800KW,50HZ,PAR)
0326-5517,11/15/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQJD,1500KW,60HZ,PAR)
0326-5447,11/15/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQJC,1250KW,50/60HZ,PAR)
0326-5434,3/12/2013 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,1760KW,50HZ,149T,PAR)
0326-5422,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER (DQKB 1500KW 50HZ 149T PAR)
0326-5420,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC 1650KW 50HZ 149 T PAR)
A049X720,7/14/2014 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLC,2500KW,60HZ)
A032Y760,11/27/2012 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLE,2500KW,60HZ)
A041K179,3/12/2013 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,1760KW,50HZ,168T,PAR)
0326-6969,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC 2000KW 60HZ 168T PAR)
0326-6927,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQFAA,750kW,60Hz,142T,EPA)
0326-6923,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQFAB,800kW,60Hz,142T,EPA)
0326-6919,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQFAC,900kW,60Hz,142T,EPA)
0326-6915,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQFAD,1000kW,60Hz,142T,EPA)
0326-6802,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLA,2500KW,60HZ,PAR)
0326-6792,11/15/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQJE; 1320kW; 50Hz; PAR)
0326-6660,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCB; 779kW; 50/60Hz; PAR)
0326-6346,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCA; 600kW; 50/60Hz; PAR)
0326-6342,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCB; 750kW; 50/60Hz; PAR)
0326-6338,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCC; 800kW; 50/60Hz; PAR)
0326-6055,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKF,1760KW,LT,TaLuft,PAR)
0326-6035,11/19/2010 (MM/DD/YYYY),CODE - DES CONTROLLER PCC2 (DQCC,825KW,50/60Hz, PAR)
0326-6027,11/19/2010 (MM/DD/YYYY),CODE - DES CONTROLLER PCC2 (DQCB,779KW, 50/60Hz,PAR)
0326-6019,11/19/2010 (MM/DD/YYYY),CODE - DES CONTROLLER PCC2 (DQCA,612KW,50/60HZ,PAR)
0326-6001,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLB,2660KW,50HZ,PAR)
0326-0340,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,1750KW,60HZ,149T,PAR,EPA,5.5GNOX)
0326-0338,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,2000KW,60HZ,149T,PAR,EPA, 5.5GNOX)
0326-0274,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKB,1750KW,60HZ,149T,PAR,EPA)
0326-0273,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,2000KW,60HZ,149T,PAR,EPA)
0326-0267,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKB,1750KW,60HZ,149T,PAR,EPA)
0326-0264,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKC,2000KW,60HZ,149T,PAR,EPA)
0326-7838,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH 2000KW 60HZ)
0326-7472,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH 2250KW 60HZ UPTLD)
0326-7428,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH 2250KW 60HZ PAR CPL8613)
0326-7385,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH, 2000KW, 50HZ, PAR, CPL8617)
0326-7359,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (750 KW PAR 60HZ 2P-2L)
0326-7355,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (800 KW PAR 60HZ 2P-2L)
0326-7351,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (900 KW PAR 60HZ 2P-2L)
0326-7347,1/27/2011 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (1000 KW PAR 60HZ 2P-2L)
0326-7321,6/20/2012 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCC T2; 800kW; 50/60Hz; PAR)
0326-7317,6/20/2012 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCB T2; 750kW; 50/60Hz; PAR)
0326-7313,6/20/2012 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQCA T2; 600kW; 50/60Hz; PAR)
0326-7271,11/15/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQJC 1100kW 60Hz PAR)
0326-7164,11/19/2010 (MM/DD/YYYY),CODE-DES CONT PCC2 (1408KW 50HZ 149 T LT TaLuft PAR)
0326-7158,11/19/2010 (MM/DD/YYYY),CODE-DES CONT PCC2 (1600KW 50HZ 149T PAR LT TaLuft)
0326-7155,11/15/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQJC 1168KW 50Hz 149T PAR)
0326-7124,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQKH 2000kW 50Hz PAR)
0326-7118,11/19/2010 (MM/DD/YYYY),CODE-DES CONTROLLER PCC2 (DQLC 2500KW 60HZ PAR)
New Calibrations for 4 - Operator Panel
0326-5468,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,FINNISH,PORTUGUESE)
0326-5466,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,ITALIAN,CZECH)
0326-5464,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,DANISH, SWEDISH)
0326-5462,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL,ENG,DUTCH,GERMAN)
0326-5460,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,SPANISH,FRENCH)
New Calibrations for 61-PCC3300
0326-7474,,CODE-DES CONTROLLER PCC3300 (PCC3300 CALIBRATION)
New Features for 61-PCC3300
0326-7017.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (150/300:X Current Transformer)
0326-7082.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (60/50 Stdby (55/45 Pr) kW 3P)
0326-7075.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (50/40 Stdby (45/36 Pr) kW 1P)
0326-7072.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (50/40 Stdby (45/36 Pr) kW 3P)
0326-7086.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (60/50 Stdby (55/45 Pr) kW 1P)
A053V904.fdl,,CODE-DES FEATURE PCC3300 (Alternator DE Bearing RTD)
A054M914.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Critical Loads(60Hz))
A054M916.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Mechanical Loads(60Hz))
A054Y650.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Start up and Protections parameters for 6BTAA5.9-G15)
A054M649.fdl,,CODE-DES FEATURE PCC3300 (QSK60 50Hz AVR & Parallel Gains)
A054N884.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Mechanical Loads(50Hz))
A054N882.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Critical Loads(50Hz))
A054X551.fdl,,CODE-DES FEATURE COMMERICAL COMMON (GENSET NOMINAL VOLTAGE: 8320V)
A054X552.fdl,,CODE-DES FEATURE COMMERICAL COMMON(GENSET Range VOLTAGE: 8320V)
A046F144.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 150kW )
A046F138.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 275kW)
A046F143.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 200kW )
New Features for 71-PCC1302
0326-7022.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (100/200:5 CURRENT TRANSFORMER)
0326-7025.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (200/400:5 CURRENT TRANSFORMER)
A050G224.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Current Multiplier 2X Enabled)
A054Y879.fdl,,CODE-DES FEATURE PCC1302 (Start up and Protections parameters for 6BTAA5.9-G15)
A030X793.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C35D6- X3.3 - 3P)
A030X783.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C33D5 - X3.3 - 1P)
A030X789.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C38D5- X3.3 - 3P)
A030X791.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C38D5- X3.3 - 1P)
A030X781.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C33D5 - X3.3 - 3P)
A030X787.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C30D6- X3.3 - 1P)
A030X795.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C35D6- X3.3 - 1P)
A030X785.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (C30D6 - X3.3 - 3P)
New Calibrations for 82-HMI320
A029T330,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,CHINESE)
A029T326,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,GREEK,HUNGARIAN)
A029T322,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,RUSSIAN)
A029T317,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,NORWEGIAN)
A029T312,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,FINNISH,PORTUGUESE)
A029T308,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,ITALIAN)
A029T304,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,DANISH)
A029T300,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,DUTCH,GERMAN)
A049Y911,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,TURKISH)
A049Y909,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,ROMANIAN)
A049Y907,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,KOREAN)
A049Y903,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,TRADITIONAL CHINESE)
A049Y901,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,BRAZILIAN PORTUGUESE)
A042L831,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE- ENGLISH, POLISH, CZECH)
A043D104,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,JAPANESE)
0326-7650,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,SPANISH,FRENCH)
New Features for 94 -PS 0500
New Calibrations for 98-PCC2300V2
A029Z601,,CODE-DES CONTROLLER PCC2300V2 (PCC2300V2 CALIBRATION)
New Features for 98-PCC2300V2
A054R976.fdl,,CODE-DES FEATURE PCC2300V2 (Fuel System - Gas, Gas fuel type - Dual)
New Calibrations for 103-HMI321
A029T338,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,DANISH)
A029T334,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,DUTCH,GERMAN)
A049Y922,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,TURKISH)
A049Y920,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,ROMANIAN)
A049Y918,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,KOREAN)
A049Y915,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,TRADITIONAL CHINESE)
A049Y913,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,BRAZILIAN PORTUGUESE)
A029T458,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,CHINESE)
A029T454,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,GREEK,HUNGARIAN)
A029T449,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,RUSSIAN)
A029T444,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,NORWEGIAN)
A029T439,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,FINNISH)
A029T435,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,ITALIAN)
A042L835,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB- ENGLISH, POLISH, CZECH)
A043D108,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH, JAPANESE)
A026G197,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,SPANISH,FRENCH)
New Calibrations for 110- Universal Simulator
A032Y611,,CODE-DES CONTROLLER SIMULATOR (UNIVERSAL SIM CALIBRATION)
Summary :
New Calibrations
3 - Genset
4 - Operator Panel
61-PCC3300
82-HMI320
98-PCC2300V2
103-HMI321
New Features
61-PCC3300
71-PCC1302
94 -PS 0500
98-PCC2300V2
- VCDS lite v.1.2 Full Activated
- Wurth WoW 5.00.08 11.2014
- The National Locksmith InstaCode [06.2016] Full + Instruction
- Delphi Cars & Trucks DS150E [R3.2015] Full + Instruction
- Delphi Cars & Trucks DS150E [R1.2015] Full Unlocked + Instruction
- Heavy Truck Service 2013 (HT13) KG
- How can I change language in Wurth Online World 5.00.12
- Latest Paccar DAVIE 4 Service Tester
- Hyundai Himsen Engine Instruction Manual
- All Freightliner Workshop, Repair and Maintenance Manuals
- CD Hyundai Heavy Duty Truck Electrical System
- Euroricambi CATALOG SPARE PARTS TRUCK
- Mitchell TruckEst Estimator v3.0.1 [2016] Full Patch
- Truck, Bus, Trailer Catalog Spare Parts for European 2006-2013
- ZF Catalog Kit April 2009
