Base Firmware Genset Incal 02.2016
WebIncal(PGA) Release :v15.11
Release Date : February 15, 2016
New Calibrations
4 - Operator Panel
10 - Keystone
52 -Slalom
61-PCC3300
82-HMI320
94 -PS 0500
98-PCC2300V2
103-HMI321
New Features
3 - Genset
47-HDKC
51-GENERIC232
61-PCC3300
63-PCC2300
71-PCC1302
94 -PS 0500
98-PCC2300V2
Detailed Description:
Cummins Power Generation has released the following new calibrations for the February 15, 2016
New Features for 3 - Genset
PART#,REVDATE,DESCRIPTION
A054H313.fdl,,CODE - DES FEATURE PCC2 (CT RATIO 600:1)
A054H314.fdl,,CODE - DES FEATURE PCC2 (CT RATIO 850:1)
New Calibrations for 4 - Operator Panel
0326-5468,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,FINNISH,PORTUGUESE)
0326-5466,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,ITALIAN,CZECH)
0326-5464,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,DANISH, SWEDISH)
0326-5462,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL,ENG,DUTCH,GERMAN)
0326-5460,,CODE-DES CONTROLLER OPPAN (PCC2 OP PANEL-ENG,SPANISH,FRENCH)
New Calibrations for 10 - Keystone
0326-0257,,CODE-DES (CONTROLLER PCATS OTPC/BTPC MAIN BLOCK)
New Features for 47-HDKC
A053V906.fdl,,CODE-DES FEATURE CONSUMER CR AAC GENSET (22 CONFIG)
A053V910.fdl,,CODE-DES FEATURE CONSUMER CR AAC GENSET (20 CONFIG)
New Features for 51-GENERIC232
New Calibrations for 52 -Slalom
0326-6955,,CODE-DES CONTROLLER MCC3320 (SLALOM COMMERCIAL CALIBRATION)
New Calibrations for 61-PCC3300
0326-7474,,CODE-DES CONTROLLER PCC3300 (PCC3300 CALIBRATION)
New Features for 61-PCC3300
0326-7049.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (SINGLE PHASE GENSET CONNECTION)
A054M914.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Critical Loads(60Hz))
A053V909.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 72:X)
A054M916.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Mechanical Loads(60Hz))
A053V903.fdl,,CODE-DES FEATURE PCC3300 (Alternator Stator U-V-W RTD)
A054M649.fdl,,CODE-DES FEATURE PCC3300 (QSK60 50Hz AVR & Parallel Gains)
A054H299.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 96:X)
A054N884.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Mechanical Loads(50Hz))
A053R848.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (50HZ G3 AVR Gains)
A054N882.fdl,,CODE-DES FEATURE PCC3300 (Genset control settings for Critical Loads(50Hz))
A040G828.fdl,,CODE-DES FEATURE PCC3300 (VTA28-G5 50 Hz)
A040R756.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (KTA-38-G5 50 Hz KVA Rating)
A054B734.fdl,,CODE-DES FEATURE PCC3300 (Alternator NDE Bearing RTD)
A046F144.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 150kW )
A031B120.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (Winding RTD Settings Class 150SB40 150degC rise)
A053P108.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 120:X)
A046F138.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 275kW)
A046F143.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 200kW )
A054H303.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 238:X)
A053H396.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 150kW Standalone)
A054H301.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 145:X)
A054H304.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 240:X)
A053H394.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 275kW Standalone)
A054H312.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 475:X)
A054H315.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 320:X)
A054H302.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (CT RATIO 160:X)
A053H395.fdl,,CODE-DES FEATURE PCC3300 (T4F Rental 200kW Standalone)
New Features for 63-PCC2300
New Features for 71-PCC1302
A054J237.fdl,,CODE-DES FEATURE PCC1302 (Fuel System - Gas, Gas fuel type - Dual)
A054J525.fdl,,CODE-DES FEATURE PCC1302 (Configurable Input #2 Function(ARROW))
A054H316.fdl,,CODE-DES FEATURE PCC1302 (AVR Gains: QSB7-G3 shunt Improved)
A054H317.fdl,,CODE-DES FEATURE PCC1302 (AVR Gains: QSB7-G3 PMG Improved)
New Calibrations for 82-HMI320
A029T330,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,CHINESE)
A029T326,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,GREEK,HUNGARIAN)
A029T322,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,RUSSIAN)
A029T317,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,NORWEGIAN)
A029T312,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,FINNISH)
A029T308,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,ITALIAN)
A029T304,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,DANISH)
A029T300,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,DUTCH,GERMAN)
A049Y911,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,TURKISH)
A049Y909,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,ROMANIAN)
A049Y907,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,KOREAN)
A049Y903,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,TRADITIONAL CHINESE)
A049Y901,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,BRAZILIAN PORTUGUESE)
A042L831,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE- ENGLISH, POLISH, CZECH)
A043D104,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,JAPANESE)
0326-7650,,CODE-DES CONTROLLER HMI320(HMI320 OP LOCAL W/CB AND REMOTE-ENGLISH,SPANISH,FRENCH)
New Calibrations for 94 -PS 0500
0326-7727,,CODE-DES CONTROLLER PS0500 (PS0500 COMMERCIAL CALIBRATION)
New Features for 94 -PS 0500
A053V856.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((24 PRIME/26.4 STANDBY) kW 3P & 1P 50Hz)
A053V886.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (15 STANDBY kW 3P & 1P 60Hz)
A053V893.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (43.7 STANDBY kW 3P & 1P 60Hz)
A053V863.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (56 PRIME/61.6 STANDBY kW 3P 50Hz)
A053V867.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (66 PRIME/72.6 STANDBY kW 3P 50Hz)
A053V874.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (35.2 STANDBY kW 3P & 1P 50Hz)
A053V881.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (52.8 STANDBY kW 3P & 1P 50Hz)
A053V855.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((20 PRIME/22 STANDBY) kW 3P & 1P 50Hz)
A053V892.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (37.5 STANDBY kW 3P & 1P 60Hz)
A053V862.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (28 PRIME/30.8 STANDBY kW 3P 50Hz)
A053V866.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (32 PRIME/35.2 STANDBY kW 3P 50Hz)
A053V873.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (30.4 STANDBY kW 3P & 1P 50Hz)
A053V854.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((16 PRIME/17.6 STANDBY) kW 3P & 1P 50Hz)
A053V861.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (50 PRIME/55 STANDBY kW 3P & 1P 50Hz)
A053V891.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (25 STANDBY kW 3P & 1P 60Hz)
A053V858.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (36 PRIME/39.6 STANDBY kW 3P & 1P 50Hz)
A053V895.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (62.5 STANDBY kW 3P & 1P 60Hz)
A053V853.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((12 PRIME/13.2 STANDBY) kW 3P & 1P 50Hz)
A053V890.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (20 STANDBY kW 3P & 1P 60Hz)
A053V857.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((40 PRIME/44 STANDBY) kW 3P & 1P 50Hz)
A053V894.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (50 STANDBY kW 3P & 1P 60Hz)
A053V871.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (100 PRIME/110 STANDBY kW 3P 50Hz)
A053V868.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (80 PRIME/88 STANDBY kW 3P 50Hz)
A053V898.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (75 STANDBY kW 3P & 1P 60Hz)
A029Z158.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((8 PRIME/8.8 STANDBY) kW 3P & 1P 50Hz)
A029Z156.fdl,,CODE-DES FEATURE COMMERCIAL COMMON ((6 PRIME/6.6 STANDBY) kW 3P & 1P 50Hz)
New Calibrations for 98-PCC2300V2
A029Z601,,CODE-DES CONTROLLER PCC2300V2 (PCC2300V2 CALIBRATION)
New Features for 98-PCC2300V2
A054J239.fdl,,CODE-DES FEATURE PCC2300V2 (AVR Gains for 5.9L Gas (ARROW) - 45, 50 and 60 kW)
A054H318.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (AVR Gains PMG Improved)
A054H319.fdl,,CODE-DES FEATURE COMMERCIAL COMMON (AVR Gains shunt Improved)
A054J357.fdl,,CODE-DES FEATURE PCC2300V2 (AVR Gains for 5.9L Gas (ARROW) - 70, 80 and 100 kW)
New Calibrations for 103-HMI321
A029T338,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,DANISH)
A029T334,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,DUTCH,GERMAN)
A049Y922,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,TURKISH)
A049Y920,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,ROMANIAN)
A049Y918,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,KOREAN)
A049Y915,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,TRADITIONAL CHINESE)
A049Y913,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,BRAZILIAN PORTUGUESE)
A029T458,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,CHINESE)
A029T454,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,GREEK,HUNGARIAN)
A029T449,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,RUSSIAN)
A029T444,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,NORWEGIAN)
A029T439,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,FINNISH)
A029T435,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,ITALIAN)
A042L835,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB- ENGLISH, POLISH, CZECH)
A043D108,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH, JAPANESE)
A026G197,,CODE-DES CONTROLLER HMI321(HMI320 OP PANEL LOCAL W/O CB-ENGLISH,SPANISH,FRENCH)
New Calibrations
4 - Operator Panel
10 - Keystone
52 -Slalom
61-PCC3300
82-HMI320
94 -PS 0500
98-PCC2300V2
103-HMI321
New Features
3 - Genset
47-HDKC
51-GENERIC232
61-PCC3300
63-PCC2300
71-PCC1302
94 -PS 0500
98-PCC2300V2
- Full Software Volvo IMPACT 2011
- Volvo VCADS Pro V2 Full
- VCDS Lite 1.0 full
- VOLVO IMPACT 2015
- Download Cummins INCAL 04/ 2013 the newest
- Volvo VCADS Pro 2.3.500
- Tech Tool V2.01 FULL Installation
- Perkins SPI 2012A KG
- Volvo prosis 2013 full active
- Metafile for CUMMINS CALTERM
- Allison Doc 8 KG
- WABCO TEBS-E v2.0 Activation + PIN
- How to your ECM with Calterm III
- CAT SIS ET CBT 2012 Master Install
- DVD Software MAN MANTIS EPC Update 477 (02.2012)
