Newest Software Full Updated 01.2017 - Doosan GPES EPC 2015- Scania Multi [10.2016] - VOLVO PTT 2.04.87+KG+DEVTOOL 2016 - JETI ForkLift (SH) v4.33 [11.2016] Full - Clark ForkLift Parts Pro Plus v444 [03.2017] - JETI ForkLift (ET) v4.33 [11.2016] - JETI ForkLift (ET) v4.32 [08.2016] Full - JCB ServiceMaster 4 v1.54.2 [2017] - CAT Lift Truck WAREHOUSE 2016 EPC - Caterpillar SIS 2016 Full [11.2016] - Caterpillar SIS 2016 Full [10.2016] - Toyota Techstream V11.30.124 [01.2017] - TecDoc CATALOG Q1 [01.2017] - BMW ETK [01.2017]- DAF PartsRapido [11.2015]- CHEVROLET Europe EPC 4 [06.2012]- HINO Trucks (LHD & RHD) Light Medium Heavy [03.2016]- Nissan & Infiniti Fast EPC [11.2016]- Renault CAN CLiP v164 [01.2017]- Delphi Cars & Trucks DS150E [R3.2014] - Mitchell Estimating (UltraMate) v.7.1.203 [11.2016]- Cummins INCAL - ECM Calibrations [12.2016] SIR + RMI- Cummins InCal Unpacker Repacker Date Changer 2016 - JCB ServiceMaster 4 v1.53.1 [2016] - Toyota Techstream V11.30.037 [12.2016]- Detroit Diesel Diagnostic Link v8.05 Full - Manitowoc Grove Service Training Full - Valtra UK Parts Books [09.2016]
Renault CAN CLiP v159 [07.2016] Full Patch + Instruction
Discussion in 'Automotive Manuals, Softwares' started by truck, Jun 26, 2016.
  1. truck
    truck S-Mod
    May 9, 2014
    2,256
    204
    If you download this document, you will be lost 2000 Gallons
    Type: Renault Diagnostic Tool.
    Region: All Region
    Version: v159
    Developer: SPX
    Platform: WinXP, Vista, Windows7
    Year: 07.2016
    Medicine: Present
    Pass: Thanks + PM Email "autorepairmanuals.ws@gmail.com"
    Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues.
    Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions.
    It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported.
    Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.
    Program dealer car diagnostics Renault, Dacia, Samsung.
    Instruction:
    1. After Instalaltion finish DO NOT run your CLiP!
    1st replace the original RSWin.exe file (backup 1st your original file!!!)
    with the Cracked .exe file in C:\CLIP_X91\Lib\Application\
    2. Now from the SAME location as you are (C:\CLIP_X91\Lib\Application\) run the RSWin.exe,
    choose "Register me now" and in the next window select "NO"!
    3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
    It will work till 31/12/2020
    4. Now as you are, RESTORE your original RSWin.exe and REMOVE the patched one!
    (Just keep a backup from the patched file somewhere...)
    5. From your Desktop anymore, run your CLiP, accept the Terms and CLiP it will load.
    You Done! :)
    SPECIAL NOTES:
    Maybe when you try to make your 1st REAL Diagnosis you received an "Error" (about CLiP Damaged...)
    try to Update your PC with ALL the Latest Windows Updates! IF again the SAME "Error"
    then use 1x other PC or Roll-Back to Version V116! CLiP it seems, she no likes some PC's!
    Also when you will make your Registration, try to have your PC On-Line to the Internet!
    IF you NOT able to use 1x other PC and you insist to use this Latest Release,
    then you can post your S/N and you will got your personal Registartion Key.
    For this workaround you will need to use your ORIGINAL RSRWin.exe and also 1st of all to
    DELETE these 2x files: "reg.xml" & "ntuser.dat" from your:
    C:\Documents and Settings\All Users (Windows XP)
    C:\ProgramData (Windows 7 32Bit)
    NOTE: BEFORE to delete your reg.xml file, open it & note somewhere your COMPLETE S/N!
    Enjoy & Good Clipping!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Download Renault CAN CLiP v159 [07.2016] Full Patch + Instruction
    Email Support : autorepairmanuals.ws@gmail.com
  2. Loading...
    Similar Threads
    1. truck
      2
      153
    2. truck
      2
      165
    3. truck
      2
      321
    4. truck
      3
      669
    5. auto
      1
      617
    6. truck
      7
      1,100
    7. truck
      8
      1,885
    8. bsnss
      16
      2,971
    9. bsnss
      12
      2,959
    10. bsnss
      2
      1,365
  3. garage
    Sep 25, 2015
    396
    85
    I really need it thanks.
    #2
  4. demagger
    Oct 14, 2015
    233
    12
    There is full model, so very helpfull
    #3
  5. Toyota
    Toyota Moderator
    Sep 3, 2012
    719
    13
    I am finding it is so good. Thanks.
    #4
  6. bigger
    Nov 3, 2015
    305
    3
    Thanks for coming and sharing.
    Sent from a mobile device
    #5
  7. cranes
    Jun 22, 2015
    440
    7
    Good job thanks for coming.
    #6
  8. honda
    Sep 3, 2012
    127
    It is perfect. Your forum is very good.
    #7
  9. momed80
    momed80 Moderator
    May 8, 2014
    472
    74
    Your forum is very good, thanks for your supporting
    #8
  10. Powerus
    Sep 16, 2013
    285
    2
    Thanks for your post.
    #9
Share This Page
free page hit counter
May doc loi | May chan doan | May test loi | Máy đọc lỗi |Máy chẩn đoán |
